Hi guys
Any idea is welcome.
I rebuilt my 04 115 this winter. Had a craked head and water went in oil. Change head, crankshat, bearing, piston, rings etc.
It started wonderfully. Run smooth like a Suzuki should. The problem is that it won't rev up more then 2700 RPM. If a try to push, it surge until a bring the trottle back to about 2700. It does it in neutral or in gear.
Is there a way to bypass the limit switch ????
I already jumped the neutral switch and no change.....
Did I miss something when I put it back together ????
Help............
Ray
Help............
Ray
