111torrance111
- Jan 8, 2006
- 273
I have a 150 yamaha outboard that will not tilt up, it goes down fine and I have checked the following.
Has good 12 volt power going to the tilt motor when solinoid is activated, you can hear it click but the motor doesn't run.
Going down works fine.
manually raised the engine & the rams both stayed down, when tested again they didn't move.
Thanks for your help.
Jerry
Jerry
