Loreto1234
- May 30, 2011
- 6
New to board-Very cool and lots of good info.
Can someone help me with disconnecting the lower end unit on my 40DT. I see six bolts and anode bolt but not sure on the Clutch Rod/Shift Rod disconnect. Do I unlock the lower bolt then turn the barrel nut above while counting the turns (because it is the adjuster) then seprate the clutch Rod from the Shift Rod? I read a post on a different Suzuki HP motor but would like to hear from someone who knows the 40DT.
Thanks for any help you can give this rookie.
