I have a 2000 Yamaha 150 2-stroke and the following has occurred and I need some input please.
Buzzer near key is going off when you turn the key on (even with engine not started / cold) and will not shut off.
-I have unplugged temp sensors in heads and it does nothing.
- Unplugged sensor in oil tank on side of engine and nothing.
- replaced main harness from guages and nothing.
- replaced harness from oil tank in boat to engine and nothing.
When I unplug sensor in oil tank in the boat, the boat runs perfect and the buzzer shuts off. I have to manually (with swich on engine) fill the oil tank on engine every few hours.
- I replaced the sensor in oil tank in boat and nothing changed as well.
If I leave the oil tank in boat connected, unplug the buzzer, the boat only runs to 2000 prm's, unplug the sensor in oil tank in boat and it runs perfect.
Am I missing anything that I could troubleshoot?
Thanks for any input....
