I have a Suzuki DT30C from 1994 that's been running fine for years. A couple of weeks ago I had some problems with the engine on a boat trip, and I've been struggeling with finding the answer ever since.
The last time I had the boat out the engine was hard to start, but I got it going after about 10 minutes. Then it ran just fine for about 20 minutes, before suddenly the engine power dropped to about 1/3. After cleaning out the fuel filter and checking a couple of other common issues, cable connection, etc., I got it going at about 2/3 engine power so that I could get myself back to the marina. The fuel filter had some water and dirt in it, so I'm thinking this could be a part of the problem. Could this explain the problems I'm experiencing now ? I assume that when I get the engine going how, it does not run at full capacity, but since the engine is on land it's kinda hard to tell.
I've tried replacing the spark plugs, cleaning out the fuel filter and controlled that fuel reaches the carborators when the engine turns over (I disconnected the fuel line at the top cylinder, cranked the engine over a couple of times and saw that fuel came pumping out). What to do next? Any thoughs and ideas would be greatly appreciated!
PS. I should also mention that I did not do any "fall-maintenance" before putting it away last year, and I did not do any "spring-maintenance" before taking the engine out for the first time this year.
