Before I took this motor it had been bored .040 over and a new crankshaft fitted. Investigating loss of comp on #3 showed the top of the piston damaged. Fortunately the bores are still good. I did find however that the crankcase is scored in the #1. Looks like the bob weight has made contact due to the previous crank or bearing failure. No biggie. The crank shaft looks good but noticed one circlip is broken. No pieces anywhere and not embedded in the piston.
I have been told that this model is prone to crankshaft failure.
Does anyone have any input on this.
One thing I have noticed is there does not appear to be much oil residue in the crankcase.
