Recently, on my return from Bimini (32 miles offshore) I stopped the boat, placed the engine in neutral, waited approximately 15 minutes (drink and sandwich) and shifted the engine back into forward gear (had audible engagement along with forward propulsion) as I went to accelerate the engine went into a high rev coupled with the sound of broken internal linkage (the sound of metal components being bounced around). I immediately shut the engine down. I waited 30 seconds and restarted the motor which was followed by the sound of a broken gear/linkage inside the lower unit. I was unable to place the engine back into gear. Engine was again shut down and left off. Fortunately, I have twins and was able to return to port (32 miles from shore) on one engine. I believe that hard floating debris may have locked the prop up temporarily (but should have spun a hub). Once back on land I briefly inspected the lower unit by free spinning the prop. When I did this it seemed like it was spinning too freely, as if not connected to anything internally......I also compared this spinning to the operable engine's lower unit and there was significant difference in the feel. I was curious if anyone else has had any issues with there lower unit malfunctioning the same way? I also noted that on the suzuki specs page for this engine it states under "drive protection" that it has a spline drive rubber hub. Is it possible that this is just a rubber hub inside the lower unit that went out (hopefully not as costly)? Back at home I drained some of the lower unit fluid to inspect for possible water infiltration and/or metal fragments with none found. I have already dropped this lower unit off to my mechanic who will in turn ship this to a lower unit rebuild mechanic but I would like to find out if anyone has any information on this subject. Thanks.
P.S. The motor/lower unit has been service annually with the water pump and thermostats just recently being replaced...I did notice that when I replaced the water pump on that lower unit the drive shaft splines had what appeared to be hardened grease inside the grooves of the splines, there was also some spline wear (minor damage you might see from hard shifting....splines were cleaned with no heavy damage noted, no internal components (lower unit) were touched.
