Re: 1989 Yamaha PRO 50. Not charging?
Have you checked the ohms (.56-.84 ohms G/W-G)) of the lighting coil or the peak voltage out (8-9 V cranking, 25 V at 1500 )put like the manual says.
I do not remember seeing any spec for ground to coil but I would think it should read open (not grounded or partially grounded)
