I have a 40 hp yamaha 2 stroke with a bad main bearing. Its the top Bearing and stamped on it is 6305 20z. I'm wondering why this bearing has 2 grooves around the outer diameter. The grooves are filled with a hard plastic and act as some type of seal I'm guessing. Im wondering if I can replace the bearing with a standard 6305 bearing that does not have these grooves. I've been told several different things. Any Ideas ?
