Re: Yamaha F115, ISC test ?
I had an ISC problem with my 2003 F115. It started to cause my ECU to freak out ...What I did first was to get a copy of the yamaha diagnostic program and made my own cable (for $30) Cause I could not order the Yammy cable cause they are back ordered for over 6 months and cost over $300 ridiculously stupid price. But the resolution to my problem was multiple, first I cleaned out the VST chamber and the screen on the bottom of the high pressure fuel pump in there, and changed all other filters and added one in between the low pressure fuel pump and the VST, (they added these from the factory starting on 07 I think). second I adjusted the TPS. third I checked the 5v reference at each sensor. lastly I touched the ISC valve body after 5 mins of run time, it was very hot. this indicated that it was probably stuck (seems to be a common problem from what I hear) I soaked it in sea foam for 2 days then reinstalled it..works like a champ now..they are very pricey or I would have just got a new one. when they over heat from being stuck it also can cause problems in your ECU ($1000) so you want to fix this problem ASAP. I am not sure of any way to test it other than listening for the ISC rattle just after shut down. I made a video of mine here ..
http://www.youtube.com/watch?v=RKGDf7zgP80 All though I heard it resetting (2 second rattle) it was over heating and stuck...my engine is running tremendously well now. if you are interested I will link you to the post about making your own cable.
