I have a 2006 70 hp 2-stroke yamaha outboard motor. When I throttle up the top cyclinder does not fire. If I put on the emergency fuel switch ,red button, the top cylinder will fire after some working with the RPM?s to get to plain. When I come back to an idol the motor runs rough with the fuel switch in the emergency poistion but will go back up to plain. If I idol for 10 minutes or so, the same issue arises. Once I get the top cylinder firing I can switch the emergency fuel switch to normal and it will run fine. If I go back to idol it does the same thing and will not fire on top cylinder and have to inact the emergency switch again.
