The steering ram on my 1986 Yamaha 70HP (70ETLJ) is locked up. i tried tapping the ram through the tube, but it won't budge past where it is now. So i purchased a new tube and bushings (i figured i'd use the existing washers). Now, i want to seek any guidance on doing this.
i have an A-Frame with a winch over the engine, and i think the bracket i am hooked up to in this photo is what i should be hooked up to?
Once i have the weight of the motor off the tube, i can loosen the nut on this side:
and then pull the tube free from this end:
Do i have to disassemble anything else here to do this?
Any input is appreciated.
Thanks,
joel
Thanks,
joel
