Re: HELP : Tilt&trim system for Suzuki df70 (2003)
The water in the oil comes from the reservoir seal. I would remove the T&T motor and try to clean it. Drain and flush the pump, try turning the hyd pump with a screw driver. You may have to replace the reservoir with a later model part. The reservoir meterial was changed.
I looked there but the parts are very expensive. I do not know whether the same set of power trim suzuki df80/90. I asked for on eBay, Amazon, a lot of other services, but nothing. Probably somewhere in America has something secondhand, but it is hard to find.
I have a 2002 Suzuki DF70 that is in the water for the season and have two questions regarding its tilt position when not being used. 1) is there a correct side it should be turned to in a full upright position or just centered? and should it be in a full upright position or slightly lowered ? Thanks in advance for your help.
