windknotnc
- Apr 11, 2004
- 45
I have a 3 cylinder 40hp Yamaha that cranks and runs perfect for about 100yds then starts cutting out and will not take the gas. It sound like it is missing and only will run about 1/4 throttle. If you cut it off and crank back up it will run another 100 yds perfect but then start cutting out. The fuel line bulb is tight, the gas fresh, and the carbs were cleaned about 3 months ago....The engine was doing this during duck season and my son cleaned the carbs and said it was running great. He ran it yesterday and today and the problem is back. Is it possible there is a stuck float in one of the carbs? Any ideas on where to start?
