I can start the motor and take cruise for 45 min during which it shows charging @ 14.8... Then it will go to 12 volts.sometimes it moves up to 12.2 or as high as 13 for a second. Then back to 12.
Then I return home and restart it after a hour or over night and it will then start to charge at normal voltage up to 14.8...
All battery cables seem to be tight at the batteries.
The first time it did that it went to a flashing 12 volts. Tightened battery cables and no more flashing.
What is the most likely problem.
2004 115 hp 4 stroke outboard with 130 hrs
