harryhardenbrook
- Apr 22, 2011
- 1
I just recently bought this boat and has run fine the first 2 weekends, then last weekend... boat had a lil problem starting at the ramp. its seems when turning the key to start it turns over..and over and as soon as i let off the key its started. all seemed fine...till went to get it up on a plain. it would bog down and the more throttle i gave it the worse it bogged down??? Checked the bulb...Tight.. checked the water seperator...no water. then the filter on the motor...red ring still on the bottom and no water in that as well??? the previous owner had lost the original key and had been using a regular metal key to start for months...no problems?? any suggestions?
