While changing the water pump I somehow changed the shift shaft position. I believe it is in forward because turning the vertical shaft clockwise turns the prop clockwise. Can I turn the shift shaft manually and if so about how far (1/4 turn, 1/2 turn etc.) and in what direction (CW, CCW)? Thanks!
