Re: 40 hp 2 stroke yamaha neutral runs perfect in gear bogs
Howdy, Jamie.
Welcome to iboats.
Join the club of people fooled by outboards that PRETEND to run fine as long as there is no load on them, then fall flat when asked to do a little work.
Your outboard is probably running on one cylinder. Try pulling (carefully) each plug wire, in turn, while at idle. The one that doesn't kill the engine is on a dead cylinder.
Troubleshoot the dead cylinder as though it were a single cylinder engine that won't run; spark, fuel, compression, scavenging,, etc.
Good luck, and let us know what you find.
