Impeller replacement 2006 Yamaha 150 4 stroke
BaileysBoat
Re: Impeller replacement 2006 Yamaha 150 4 stroke
Not a hard job with the right manual, about the same as any outboard. Don't forget the lower unit bolt hidden under the trim tab.
Order the whole kit with impeller and cup.
And do yourself a favor and order a new woodroffe key. Sometimes they seize in the driveshaft.
Best of luck.
robert graham
I did mine a few months ago and it wasn't near the nightmare I heard it could be. Just take your time and you can do it in a couple of hours. Check: simyamaha-Andy's tips for instructions with photos on this and several other repair/maintenance procedures. It's very helpful, and good luck!
