stuart3311
- Apr 13, 2011
- 1
I need some assistance in troubleshooting a problem with a 2010 6 hp Yamaha 4 stroke that won't run with choke in. The SELCO manual for Yamaha 4 stroke outboards does not seem to address the problem in the trouble shooting section.
The symptoms came on slowly after buying fuel for the outboard in the Abacos. At first the engine would run only with the choke half way out after starting. The problem has progressed and now the engine will only run if the choke is left pulled out after starting.
I have removed and blown out the fuel filter, disposed of the old gas, purchased new gas that with an octane rating of 90 that is ethanol free. I have also added a fuel additive to the new gas which kills algae growth. After these steps were taken the problem still persists even after a few days of the fuel sitting in the carburetor.
Do I need to remove and clean the carburetor or is there another step that should be taken first?
Thank you in advance helping.
Stuart
Stuart
