hutchinsglen
- Apr 10, 2011
- 1
the engine in question is a 2000 dt200 . the engine is running perfectly but lately when we come in i am finding water in the bottom of the engine cowling.we have dried out the area and put on a hose at the house and can find no apparent cooling leaks or water filling up the engine compartment. but as soon as we drop it in the water and run for 10 minutes there is a couple of inches in the rear of the cowling. when i fill the cowling manually with a hose water appears to leak down the lower unit from behind the cowling cover on the front of the engine by the main steering yoke. any advise would be appreciated as to what posible seal is leaking. the main engine cover gasket is in excelant shape. thank you
