Re: Yamaha 150 Dirty Carburetor
No way it's gonna happen. To clean carb internals/jets you have to remove/disassemble/clean, re-install and synchronize them. A Yamaha dealer can do it for you. Some pretty good mechanical types do their own. After you get carbs cleaned and set, install a water/fuel separator type filter and use a fuel stabilizer like Stabil or Seafoam all the time. Good idea to drain carb float chambers every now and then. Good Luck!
