I have a 1991 DT55 that sat for two years. I removed and cleaned carbs and it ran good until full throttle then it would loose power and beep. I cleaned what I thought was the oil flow sensor and now it runs rough and lacks power. All cylinders are firing but it seem something is not allowing it to run full power.
Will the Oil injection cause this? If so what needs to be replaced? The Oil container or the Sensor?? Any advice appreciated...
