planes up good then shortly after looses half power
B belize52 Recruit Joined Mar 21, 2011 Messages 2 Mar 21, 2011 #1 planes up good then shortly after looses half power
R robert graham Admiral Joined Apr 16, 2009 Messages 6,908 Mar 21, 2011 #2 Re: 100hp yamaha with throttle body carbs Check fuel delivery from tank pickup, fittings, primer bulb, quick disconnect on cowl, fuel pump, fuel filter. Sounds like a fuel delivery or restriction issue. Good Luck!
B belize52 Recruit Joined Mar 21, 2011 Messages 2 Mar 21, 2011 #3 Re: 100hp yamaha with throttle body carbs could water in gas cause this
9 99yam40 Fleet Admiral Joined Sep 7, 2008 Messages 8,874 Mar 21, 2011 #4 Re: 100hp yamaha with throttle body carbs yes it could
