Captn Dave
- Dec 5, 2001
- 176
I've come across a 1998 Yamaha 200 SWS II that I'm considering buying but the owner says it has a tendency to overheat at WOT.
The water pump and thermostats have been replaced.
The engine is overpropped. It only hits 4800-5000 at WOT.
I've done some research and have found that the cooling passages in the head and block can become blocked with scale but they can also be cleaned.
Should I pass on this engine?
