boomhauer1032
- Feb 19, 2011
- 4
I recently pulled all of the witing off of the old breaker panel to rewire only the necessities. I installed a nice blue sea fuse block throughwhich I ran the electronics, nav lights, and bilge pumps. After cleaning the swith panel of the old stuff, I ran the pumps and nav lights through the switch panel. Everything looks and works great, except that I lost power and backlighting to the tach. There is a 3 wire harness (black,pink,grey) that came off the old panel which plugs into a harness with 4 wires exiting (purple, pink, grey, black). The grey wire entering is the power to the backlighting as the lamps come on if i jump power to it from the fuse block. It must be grounded, but im not sure where. The exiting purple butts to a yellow daisy chain running to all the instruments, but goes through the ignition i think before going to the tach. The black exiting butts to a blue daisy chain also running to the instruments. the pink and grey exiting both run separately to the gas gauge. I tried to jump power to the entering black and pink, but the tack wouldnt come on. On checking resistance, the grey entering was a complete circuit using the block for ground, but the pink and balck were not, even with the key in on position. The tach worked fine before I pulled everything, but not sure how to power it up again. Boat runs fine without it, but Id kind of like to have it.
Any help appreciated.
Mark
Mark
