Re: Yamaha 225 on a key west 23 ft boat
Ok Sparkie, What I was getting at is that your speculation of the high 30's is far short. I have researched this to the ends of the earth to get my boat where it should be; and against the opinion of a ton of folks, I was able to obtain a prop (based on the performance bulletin) for my boat and I am happier that a pig. Room for improvement? possibly. But close to 50 mph at 59 to 6,000? how and when can you go faster. I have an 04 225 yami and that is the recommended rpms. The regulator/limiter will/should kick out at approx 6200. However, I know what the OP is talking about.. the boat is "tough" to get up if you baby it. Like my original post said, trim down, tab down, and get right onto it! Then throttle back when you are on plane (which is very quick). So what I am saying is the F225 is plenty of power for that boat. It is imperative that it is propped correctly, and as someone else mentioned the height of the motor is also important. Bottom line: check the performance bulletin which will tell you the test prop, motor height, and test conditions. Easy place to start.
