Greetings ?
I have a new-to-me 1999 Suzuki DT85 on a 17 ft Key Largo that has probably spent its life in/near salt-water. It runs fine and is in good shape, and looks like it may be a keeper for quite awhile.
However, shifting into reverse seems to be very hard (compared to shifting into neutral or forward), almost as if it?s binding somewhere. I disconnected the shift cable and it is smooth and even throughout the full range of the console shift-lever, so that?s not the issue. But with the shift cable disconnected, I tried to move the shifter on the engine and it was very hard, leading me to believe the problem is somewhere in either the shift-shaft itself or in the lower unit/gearbox.
I dug thru some posts here and also looked in the Seloc and Suzuki repair manuals as well as the Suzuki parts manual, but haven?t found anything that would help diagnose any further. I?ve rebuilt cars and such in the past, so I know which end of a wrench is which, but have never broken open the bottom-end of an outboard.
I am mindful of its probable salty history and all that it might entail, but I am remaining optimistic. I?d appreciate any guidance (or hand-holding) as to where to go next with this. Is it something that can popped open fairly easy to check or make adjustments, clearances, etc, or do I need to get ready for major surgery? Everything I?ve seen so far indicates that there are some adjustments (clutches maybe?) that might help ease the hard-shifting, but haven?t found anything that directly points to where to start.
Thanks in advance.
Thanks in advance.
