i replaced the impellor in a 2001 yamaha 40hp , it seems to have intermittant air in the pee stream . is this normal? could the intermitt air be do to cavitation? also it had a very soft sounding "chirp" prior to the impellor change , but no longer hear it. could it be related to the water impellor? temp didnt get over 83.9* with a hand held infrared temp gun. the water temp was 55* during the water test. when you raise the rpms you can see a stronger pee stream, that tells me the pump is doig its job correctly.
