Re: 2002 Yamaha 25hp 4 stroke water pump replacement
Sure hope you are not out but a few miles when the pump craters and have a good battery and trolling motor or paddles as I have seen some even less that 5 turn loose from the shaft hub and mine that lost a few vanes in less than 1 year, best to follow the recommended PPM and keep an eye on the stream just be sure.
