No the above will not do it, you will have trouble. With todays fuel you must run stablizer through it and I would drain the carb float bowl (usually a small screw on the bottom of the float bowl). Pull the plugs and put 6 drops of oil in and pullit over by hand 2-3 times. Change the gear oil. - Bob
