Re: 2006 Yamaha 8hp will not go into reverse, how do you disconnect the shift linkage
I just figured it out, thanks.
Prop shaft and drive sheared. I try to post pics......
Sorry to hear that. What happened?
I just finished pulling the bottom end to do an impeller inspection. These things aren't quite as easy to work on as my other engines. I found that getting the boot for the shift shaft back in on the bottom end to be a bit tricky. A little marine grease helped.
Good thing we have each other to provide assistance. For a boating forum, they're not exactly "jumping into the boat" to help. Maybe it's because we're talking single digit horse power. Unless of course, you and I are the only participants with small Yamaha outboards.
