Howdy,
My Suzuki is having a small problem, after I put the cables on the battery backwards in the dark (please save jokes until after giving advice.) After this, the starter no longer spins at all, and the electric choke does not work, nor does the horrible buzzing alarm sound when the key is turned without the engine running.
engine still starts and runs like a champ with the pull cord, the key has to be turned on for this to happen, and the key stops the motor when turned to the off position. I have replace the only fuse I can find, under the cover, and in a black rubber sleeve. I can not find a fuse in the control box.
Any ideas on how to fix my problem?
Thanks guys, I got help on this forum with my old 50 hp johnson, hope someone can get me moving in the right direction now.
