have replaced fuel pump , fuel supply hose an primer bulb , cleaned carb bowl out
J john5454 Recruit Joined Oct 30, 2010 Messages 1 Oct 30, 2010 #1 have replaced fuel pump , fuel supply hose an primer bulb , cleaned carb bowl out
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Oct 30, 2010 #2 Re: 1990 yamaha 30 hp dies at idle What was in the fuel bowl that needed cleaned out? What ever it was probably made it's way into the idle circuit and has it plugged up.
