Hi, I have a 1986 V6 Special J and when ever the key is on the oil pump to the engine mounted tank is running causing the engine mounted tank to overflow. I am confidant that my engine mounted oil sender is working properly because when i let the float fall to the bottom the alarm sounds. I am leaning to the oil control module however I am unsure on resistance specs on testing the module the wires going to the sender are red, white, black, brown. thanks for all your help in advance.
