My Yamaha F225 (2002) idles fine in Neutral but runs rough when I put in Forward at idle speed. Even a little throttle makes it run perfectly again. ONLY rough in F gear and at idle speed. Is it possible to have the prop nut to tight...just enough friction to strain engine and make it run rough until juicing it up? Any advice?
