Suzuki DF175 high idle
parrott
just installed a used DF175. I'm experiencing a high idle in the water of 1000-1200 rpms. Any suggestions?
waffles1
Re: Suzuki DF175 high idle
The idle won't adjust down with the idle screw adjustment?
rodbolt
EFI does not use idle adjustment screws, however if something breaks it idles about 1100.
or the cable adjustment is out.
do you have the suzuki multifunction tach.
I do have the DF175 manual just not here, its actually at home.
