Hey guys,
Finally got the boat into the water after a full powerhead rebuild and oil transfer fixed. Put her in, hop in only to see it wont engage reverse. Just get a whole lot of clicking. Would go into fwd fine. But after a bit of fiddling around with cables and so forth it wouldnt do anything at all.
Back out of the water to inspect and see that the shift rod is about 3mm diameter at the bottom, and was not turning when moving the fwd controls.
So my question is, what is the process in changing these? From what I have read it is a powerhead off job.
Now luckily there is still fresh grease on the power head bolts, so I am going to tackle this on my own, with hopefully some help from you guys here.
Model is a 200 beto 6G6 UL 588 761 C
Is it a simple case of removing the 10 bolts (2 frnt, 2 back, 3 on each side?) along with the cables, lines and wiring harnesses?
Is there anything else to look out for?
Will I need to remove the bottom leg first?
Please excuse my lack of experience. I have only purchased this boat but is my 4th yamaha. I have always paid to get things done but the last 3 experiences with qualified mechanics has only left me broke and dissapointed.
Thanks in advance for your help.
