im looking to buy a used boat with a 2007 f115 when i went test run the boat they had a alarm go off and reduced rpms. when tried to get on plane. the guy im buying it from brought to the shop and said it was a loose ground under the console. ive had 2 strokes but this is my first 4 stroke does this sound right would a loose grond cause this ??other than the motor run fine
