Re: suzuki DT85 wont get past idle
I'm having the same problem with my DT65 suzuki. Cleaned the carbs; changed plugs. checked compression; 120 all 3. Starts good, idles good, revs up with no load great. RUNNING AT BOAT LAUNCH on trailer, i can trim up and put it into gear and rev up to 4000 -5000 rpm no problem and trim down to apply load and it will run fine under load. If I throttle down to 2500 and go back up no problem. If I drop below 2000 it will start to stall and die. IT JUST WON"T JUMP THE HUMP TO GET UP. DRIVING ME CRAZY. My problem started will running 3/4 throttle (just thought man motor is running great) then started bogging down and killed. Started it back up and idled to launch because it would never get up. Just changed throttled sensor to the ic ignition and no help. ANY suggestions would really be helpful. Thanks Rowdy
