Hi,
I have a Yamaha F100 TLRA -I looked at the parts scheme and see 2 oil seals 93101-25M03-00 sitting on top of the bearing housing. On my motor, I can only see 1 seal after removing the prop. And this one seal seems to be glued to bearing housing. How do I replace this seal or both seals?
Can someone confirm the seal sits on top of the bearing housing?
Thanks in advance!
Thanks in advance!
