compression test on 90 hp yamaha
ssoileau
Did a compression test on my 1998 90 hp 2 stroke yamaha ( C90 TLRW) Got between 50 and 52 psi on all three. From what Iv'e read, that seems low. I pulled all 3 plugs, throttle wide open and turn it over 5 or 6 times. Checked it twice. It runs fine, has enough power to pull two people on a tube. Need some feed back.
noelm
Re: compression test on 90 hp yamaha
try with another tester, yours may not be reading right!
robert graham
If the motor runs fine, idles good, pulls tubes, wide open throttle around
5500RPM's, then why worry about the compression?
