Re: 2001 Yamaha 60 hp water question
You should post model no for the best response. If no water discharge your best bet is to drop the foot and inspect water pump- impeller.This would also be a good time to change thermostat and poppet valve. This way you start fresh and know what you've got from the git go. Lots of info here just use search feature.Don't run it as is or it's toast. The manual is very helpfull also.
