This engine dies at idle after you have run wide open for a moderate period of time. But it only does it every once and a while. You can run it wide open draw back to idle over and over again. But about 1 out of 10 times it will die. and then won't crank back up with out using the warm up lever. I have changed the boat fuel water sep, the low pressure fuel filter, and the high pressure fuel filter. No codes come up.
