trying to identify the recirc valves on my intake,i have a brass nipple/tee, that is looped to a single nipple, which one is the recirc valve, and finally which direction is flow, thanks
should flow from the intake to the block.
use a syringe filled with alcoholand a piece of tubing.
you should be alble to push it in but not suck anything out.
