Hi,
I am putting my boat back together with New Pro Series 11 analog gauges on a 2010 115 4 stroke, and have some problems. I can't find wiring schematics anywhere.
I think the water pressure sending unit is in the right place. There was a plug there with a plastic washer which I removed and the sending unit threads right in. The pic below shows it on the starboard side of the engine.
The other gauge I am confused about is the tach with oil and temp warnings. I have the correct harness for the tach which goes from the engine to the tach. It has a female plug end which goes to the male on the tach.
However, there are two other wires which I don't know about and there is no plug end in the accessories harness, or key switch harness for them.
They are the yellow with red stripes and the pink with red stripes.
Any help would be greatly appreciated. Thanks.
Cheers,
Jim
Cheers,
Jim
