I looked at a used boat today with a 150 TLRU. Hooked up the hose with the rabbit ears and started it up. It didn't want to idle so I gave it some gas and revved it a bit maybe up to 2500 rpm ( the rpm gauge wasn't working). It took maybe 20 seconds before I got a stream from the tell tale. Then the overheat horn came on and when I cut back to idle it quit. So we waited a couple minutes and started it again, this time at idle with out any throttle. It ran now at idle and again took about 20 seconds for a stream from the tell tale, the overheat horn still sounding all the time. We let it run maybe a minute and the water coming out the tell tale was not even warm until the engine was shut down and then the stream got warm as it continued maybe 5 seconds after shut down. The boat owner said he just had it out last week and got no overheat horn, and he blamed inadequate water supply from the hose.
My last outboard was 73 1150 merc with no warning systems, rip. So I'm wondering if it is unusual to get an overheat warning from this motor when running it from the hose and maybe I revved it too much to start, or if there are some cooling issues, be it thermostats, pressure sensor grommet or impeller.
Thank you to anyone that can shed some light.
