keithpowell
- Jul 12, 2010
- 1
I have a 1994 Suzuki DT55 outboard(oil injection) that seems to have a fuel related problem. when I brought it out of winter storage & filled it with new gas and the engine would not revup which seemed to me to be gumed up carbs. I took the 3 carbs off and cleaned them although they seemed to be very clean. I replaced the spark plugs and fuel filter and back to the lake for trial and results were the same! The problem appears to be in the the two bottom carbs(2&3). If I spray carb cleaner in either of these 2 carbs the engine revs up. The compression and firing seems to be good in these cylinders. If I slowly increase the throtle at about half open one of the bad carbs starts to run a little but if i continue to increase it drops out. Any suggestions? Keith
