After running the motor for about 45 minutes on and off plane I got a warning buzzer. I checked the resevoir oil level and notice it low so I added oil and thought that would solve the problem. Unfortunately the buzzer hasn't gone away. The buzzer sounds even without the engine running, but it is peeing like normal and it seems to be running fine (other than "limp" mode).
I have noticed on other threads that it could be the water detect switch in the engine mounted fuel filter, the filter cap, and even the oil tank sensor. After reserching the Yamaha site I only found the filter cap for my model so I wanted to double check that I am not missing something??
Also any other suggestions are much appreciated.
