My Yamaha Saltwater Series II V250 OX66 (L250TXRW) has stopped going into gear (forward and reverse). This winter I replaced the throttle gear box for my twin outboards after having trouble with two of the engine tilt rocker switches. When I launched, starboard engine was fine, but port was rough when going into gear, but sounded ok as it was given more gas. It sounded as if it was having trouble moving into forward and reverse gears, but ran well once it caught. Thought it might be a cable adjustment related to new throttle controls. Ran fine for 15min on launch day, but second time out, 10 min into trip at cruising speed engine lost forward movement. Engine sounds fine in neutral, but will not go into forward or reverse. Checked all cable and controls and their movements match those of working twin. Everything up to the pin/bar that rotates before it dissapears into the bottom looks good. Local mechanic told me gears in lower unit, and would need new one. I ordered and switched out a new lower unit Saterday. No change. I have never replaced a lower unit but was given lots of direction, and it went well. So that's everything so far. Advice?
